I am contemplating connecting a "recovery tank" to the radiator on my `83 505 but I have encountered a slight problem with a replacement rad. cap I want a 4Psi one but the lowest pressure available seems to be 7Psi
Recovery caps look just like any other ordinary cap but have 2 rubber seals the extra one is under the top instead of or in addition to the usual brass plate.
The overflow pipe becomes the recovery pipe from the non pressureised catch tank
My present temporary set up that is working remarkably well simply has the overflow pipe into a 2 litre plastic milk carton with a zip tie through the handle blush
Wet sleve engines in general appear to be more prone to "mayonnaise" in the sump and breather than other engines I suspect this is due to the bottom seal of the piston liner leaking slightly ( although I once had a split liner and that gave great blown head gasket symptoms ) so I think any increase in radiator cap pressure would make this worse
I have been looking at propietary cooling system sealers "irontite" "barrs leaks " etc and reading the directions they mostly state the engine has to be free of antifreeze/anticorrosion
except for one called silva or silver seal . What do other owners use?
Any knowlegable comments and information on a cap supplier gratefully accepted many thanks in advance. tongue
Cheers Ranger
"The more you prepare the luckier you get"
Cheers Ranger
