- Joined
- Aug 2, 2000
- Messages
- 11,484
Well I finally got the 309 GTi16 gravel rally car going again today after being off the road since late March. It dropped a valve during the Classic Outback Trial and around the same time the bodywork around the engine mount tore apart. Body work was fixed by Nick at Lux Racing, once again a great job, he thought that it wasn't spot welded correctly at the factory, Ryton in the UK. I built up a 1.9 to replace the 2 litre XU10 with 1.9 head and Piper cams that I had been using. The cams were low duration but high lift which may have contributed to the head dropping off a valve. Ifitted a head with a fair bit removed on the new 1.9 and a Peter T Stage 1 cam, which was ground by Crow in Melbourne who have taken over Peter's cam profiles. Even before tuning it goes very well, response in first gear is amazing, you can be idling along in gear, flatten the throttle, then instant wheel spin and rev limiter.
