I have a lock nut that has come apart and is unable to be removed.
The tyre is fine for the next year but if we have a puncture it'll be a tow truck as well as having to deal with the issue in question.
I would rather solve it now.
Here is a photo. I tried to drill the centre and I hit it with a hole saw quickly before wisdom got the better of me and figured asking for advice might be the best first step.
Here it is. The diameter of the centre nub is 12mm
Here is the existing lock nut and removal tool.
I believe the lock nut was fitted with a rattle gun and was obviously too tight to remove, or had been damaged when fitted. It sheared off when we tried to remove it with the wheel brace.
Tyre place said they are unable to deal with it.
I was thinking to use a hole saw to remove the wide part of the nut that is holding the wheel on, that way we can remove the wheel and remove the remaining stub with the 17mm removal tool at the tyre place.
Let me know if you have any other ideas.
