Hi,
Really hoping someone can help. I've just bought my first French car....and I'm loving it. I just had to buy it....like new inside, super economical, relaxing (not fast!!) to drive and it was really cheap cheap. I'm intending on towing my lightweight Westfield race car with it. All up the towing load will be < 800 kg so should be fine.
A module which has the following labelling...” Siemens VDO bsc a01-00 9656147980”...came with the second hand towbar which I have fitted to my Peugeot 07 SW (June 2004 2.0 hdi 66kw build).
I'm hoping this module is the interface between a trailer wiring harness and the vehicle wiring loom.
As this vehicle may be either a VAN or CAN bus wiring schema I'm not game to directly wire into the rear lights as in the old days. I suspect the module that came with the towbar is the missing link....if only I could find out the pin outs!! Or can I just wire directly into loom...it is a very early 307 (6/2004).
I have been trying to find this pinout or wiring diagram information for this module with many failed Google searches. I've also tried contacting Siemens/VDO ... they don't answer their emails!!
Hopefully someone may know where I may purchase the missing 16 pin compatible plug.
Hoping you can point me in the right direction....Google hasn’t helped!!
Thanks very much
David
Busselton
West Australia
Thanks very much
David
Busselton
West Australia
