307 ignition coil wiring connection
405STi
Hi all,
The wiring/connector that goes into my ignition coil seems to be very temperamental.
The car was idling really rough, and had low power, wouldn't get above certain revs for example, and then the next time i started it, the car would be fine.
I unplugged the connector and plugged it back in and the the engine wouldn't turn over at all. A few more wiggles of the cable/connector and now its working again.
Can anyone recommend someone (Peugeot mechanic or auto electrician) in Sydney who would be able to check/rewire/replace this fitting? Seems a finicky task suited to someone who has done it a few times.
Thanks in advance
Evan.
What motor the tu5 coils are common to break in the coil just under the plug also the wiring can short on the head causing random missing and no start
Garage C5 X7 3008 XTE
Fix it right the first time
