I have recently purchased a 2007 307 with the 2.0 16V petrol engine EW10A/RFJ. that has developed a hesitation and lack of power at low RPM (800-1500) particularly with sharp throttle openings off idle. It is much worse when cold and will sometimes stall. It doesn't seem to have any issues until about 5-10sec after staring from cold (guessing it is when the car is operating in closed loop). If I hold the revs at around 1200rpm then snap the throttle open it will misfire and stumble then rev as normal. It accelerates and revs normally once above 1500rpm. It will do this when in neutral also so not likely to be transmission related. It does not show any fault codes.
It is staring to drive me nuts and cost me a small fortune as I have replaced a number of parts that could cause similar symptoms. This is what I have done so far with no success.
Spark plugs (Bosch)
Ignition coil (old one had hairline cracks in it)
Engine flush (liquidly engine detox) and oil change
Fuel filter
Fuel pump
Coolant temp sensor
Crankshaft position sensor
Removed and cleaned injectors (not professionally cleaned but flushed them thoroughly with carb cleaner while cycling them on and off and removed any deposits)
Cleaned throttle body
Cleaned intake with Liquimoly Petrol engine intake de-carb
Full tank of Liquimoly injector cleaner
Checked ECU wiring for water damage
Checked injector resistance at cold (#1-12.5ohm,#2-13.1ohm,#3-12.5ohm,#4-12.4ohm)
Can't find any obvious vacuum leaks
Has anyone come across similar issues with this engine or model that could give me any advice?
Spark plugs (Bosch)
Fuel filter
Fuel pump
Coolant temp sensor
