I recently cut the tops of the 4 black relays and the bottom off an old engine slave / fuse box. This reveals a sandwich of two boards about 1/4" apart bonded into the housing with encapsulant around the edge of the upper board. It's not ever coming out of that housing. You can see, but not easily get at the solder points for the larger relays. On this particular unit it was clear that the failures were a melted contact support in one supply relay and melted/dry joints for the same relay and at another one. I have seen one video on Youtube where someone removes a faulty relay from the top, solders in some pigtails and adds in a new plug-in relay to repair it. That is an option as it means you don't have to get to the underside of the board. You have to physically destroy the relay to remove it and there is a risk it will damage the solder pads on the part of the board you can't get to or let some solder inside that might short out one day. Dry joints can cause all kinds of issues unexpectedly, but eliminating bad earths does mean one half of the circuit is likely to be good now.
