Hi guys,
Having an issue where the cooling fans run on low speed for about 5 minutes after turning the engine off. The dash STOP light is also coming on after driving for some time. If I stop and let the car cool down, the STOP light goes off. When I did this I opened the radiator cap, coolant looked fine (no boiling/steam). Was a hot day with some traffic so I drove it home by disconnecting the brown sensor to force the fans to run high speed - the STOP light did not come on, however the fans still ran for about 5 minutes after I turned off the car.
The temperature guage on the dash is below 90 deg when the STOP light is coming on, and doesn't go over that.
When I disconnect the brown sensor on the thermostat housing, fans are low speed for a second and then run high speed. I replaced the brown sensor about a year ago (in error at the end, problem was fan was worn out). Connections on that and the other sensors there look clean and ok. Earth points under the battery and down under the enging (gearbox?) look ok.
I have read some posts about wiring looms causing problems. The connector uder the fans on the passenger front side doesn't look to be in great shape.
All levels are ok - coolant, oil, brake fluid, power steering fluid.
It's a 2000 Phase 3 XT with a 2.0 lt.
Any thoughts on where to next? Could it be the Bitron fan controller (mine has a cartier branded one)? Or the wiring connector? Or a faulty temp sensor?
What's the downside to driving it with the brown sensor disconnected (to force high speed fans)?
Thanks!
Thanks!
