Hey guys!
Over the last few months my 3008 started giving me low oil warnings (to top it up, not critical). The first time this came up I checked the level and it was above 1/2 on the dipstick. I added about 200ml checked the dipstick again and it was up to about 3/4.
The warning is coming up again nearly every time I start the car. The oil level physically is totally fine, no issues, no leaks, no mechanical problems.
The warning does appear before I start the car. When I get it in the car it is already flashing. It does, however, not appear again if the car is turned off and then turned back on. Before I thought that this is because when the engine starts, the oil naturally rises and the sensor is "satisfied", but I have now discovered that even just turning the power off and on is enough is enough to clear the warning.
So, I get low oil level warning despite its being nearly full, then I turn on the power without switching the engine itself on, the warning beeps, and immediately after that I turn the power off and ignite the engine. The warning doesn't comes on again.
I think that this hints that this is purely sensor/electrical/software failure.
Car has 119k on it and it the 1'6l petrol version (chain not belt) and is due for a service in shortly, but I wanted to see if there is any knowledge here about this. I've read on other forums where others have been experiencing the same issue, but seen no resolution.
