Going to be for road use only. Probably just a stage 1 tune and some visuals really. Wheels etcYou've got a hell of a lot of kW already out of the engine, and a fairly light body. Do you want it optimised for the road, or do you wish to race it?
Perhaps the first step is to make sure the computer has no errors stored. Do you have a code reader?
Thanks heaps for the info. Definitely noticed the temperature. Will check out etunersTons of info on etuners.gr - they were the pioneers of toying with the 1.6L THP. Check out https://www.etuners.gr/category/ecu-remaps/peugeot/208/
As they will tell you, depending how many kms on the car would recommend an inlet walnut (or similar) clean before any sort of tune. That will at least unrestrict and restore factory flow that is compromised by carbon build up on the direct injection head.
Next would be K&N or similar panel filter in the std airbox. Many tests have shown pod filters may sound better but give no performance gain. After that a GFB diverter valve would be next before you should consider a remap.
Be aware inlet temps run high even in stock trim so an intercooler upgrade should be high on the list if you remap in the warm climate of Brisbane.
CheersPeugeotech in Brendale can also do a stage 1 tune.
Will do. Have to sell the moto firstPlease update this when/if you get it performance tuned. I'm also in Brisbane.
