Hi,
so I've had my car for a month or so now and I'd like to start tinkering with it. I'm not looking at making this the fastest car ever, an affordable 205 that is comfortable and can go decently quick on windy roads, dirt or at club events. The car is fine right now, but there are things that could be improved.
I've been reading about suspension upgrades to the 205 and what cheap options there are for my si and I was wondering if i could get some feedback from the community.
First thing is the suspension. When I have googled 205 suspension upgrades there have been a lot of options, adjustable coilovers, billies and koni's etc but there is always a comment that says what the peugeot engineers have done is just about right so don't mess it up so I'm going to try and stick with this ethos. This article has also helped with my decision making https://www.205gtidrivers.com/forums/topic/120157-how-not-to-modify-your-205s-suspension/
The plan at the moment is this.
- Look for a gti rear end or rebuild the one in the car and add a thicker rear ARB
- rear shocks from a xsi/gti6
- replace front shocks with xsi/'6 shocks, s2 405 top mount, springs of some sort...
I'm not sure what to do about front springs. Will the si springs be ok to go back in? Is it worth it getting them reset? Is the any difference between the si springs and the gti?
Would using parts from other Peugeots be a worthwhile upgrade or am I better off buying some bilsteins and eibach springs?
The car rolls around quite a lot, I have run it at a few bitumen motorkhanas now and have come to the conclusion that I would like it to sit flatter when cornering. Grip doesn't really seem to be an issue even with how much it rolls but it would be nice if it felt a bit firmer.
I'm going to look for some 266mm discs and calipers from a 306 too. The standard 247mm solid rotor isn't cutting it. For a car that weighs so little it stops so slowly.
The last thing I would like to do it throw my mi16 motor into it. Maybe over xmas. I will be doing more research into this but are there any in depth guides about this swap? I want to know everything I need and what problems I might encounter. Alternatively is the anyone in Melbourne that has this swap that I could check out and talk to the owner?
