I can't see a problem in the short term with wiring the fans to the ignition.
I popped into Repco and they couldn’t seem to find an equivalent Narva part, had 20amp and 30amp but not 25 for some reason. Is their OEM relay (g.Cartier) the only option?Yeap, it could. It can be other things too, but the easiest thing to do is replace the relays with good ones and trying that. I would try replacing them one by one to see which one makes a difference, maybe not all relays are bad.
Good idea. Will check that thanksWhen burping the air out of the system on a 205 si, you need to lift the bottle up really high. Remove the rubber strap and make a hook out of a coat hanger and hang it from the bonnet edge. (ie eye level).
Worth checking the small hose from the top of the radiator to the filler tank, they block up with junk.
Also, you can always just press the ac switch on in traffic, turns the fans on as well and drops the temp.
This link (it's a long one) will take you directly to a list of fan types post 1991 XU models. Copy and paste.
OEM numbers and fan thermostat details are there for most of them.
If your model is earlier or a different engine variant go to the catcar homepage for Peugeot (below), select the model 205 and open the relevant link to the diagram of your model.
For example my 309 pre 1991 XU5 JA (B6D) 1.6 injection 113hp has 1264 21 97/92 degrees
If the 6 figure OEM number is no help at the parts store at least the on/off temp can guide them.
A search for an OEM number should bring up lots of listings on ebay and various northern hemisphere parts suppliers. Some of the search results will give thread dimensions will also help at your local parts store.
I have attached a screen shot from servicebox that show many temp listings for 309 XU5. It might help you identify your specific thermo.
Some models run two stage thermostats which I am unfamiliar with.( 1264 22 97/92 - 101/96 degrees) Two-stage fan speed or one fan and then the other?? I am not sure.
Perhaps the manufacturer of your present thermo. switch has stamped the temp. rating on
Hi Peter, do you know the part number of the sensor is or temp range please? I’m assuming it’s “1264…”There are three relays to control the two fans. When on low speed the fans are connected in series. When on high speed the fans are connected in parallel.
There is a sensor in the LH side of the radiator which turns on the relays. Remove the connector. If you connect two of the wire (not sure which two) the fans should go to low speed. If you bridge out all three wires the fans should go to high speed.
I have a schematic if the above doesn't help solve your issue. ie it's more than likely that the sensor has failed.
A new sensor is approx. $90. I think Adrian still has an Si in his front yard. You could offer him $40 for the sensor?
Thanks Peter126445 would be my pick. Make sure you also have a 92º thermostat to match. You can choose a lower temp switch, but always have to match the thermostat.
TP Radiator Fan Temperature Switch Fits CITROEN ZX PEUGEOT 205 306 405 126445 for sale online | eBay
Find many great new & used options and get the best deals for TP Radiator Fan Temperature Switch Fits CITROEN ZX PEUGEOT 205 306 405 126445 at the best online prices at eBay! Free shipping for many products!www.ebay.com
