205gti (1.9 s1) ignition / electrical gremlins
Billy
Hello,
I'm having a little worries with my 205 - the ignition seems to be breaking down when the engine gets hot. I don't think it's running excessively hot but a little higher on the gauge than it used to.
The battery light on the dash has been glowing a bit for about the last two weeks when driving at night. last weekend I checked the battery voltage which did drop to just over 12 when started, but at an accelerated idle went up to 13.8.
So a little suspect on the alternator, or the ignition coil.
anyone else solved similar problems?
thanks,
Simon
i wouldn't worry too much about the battery light (glowing slightly). it tends to be a leak somewhere in the electrics.
when was the last time you changed plugs, leads, and coil? how many kms do u have on the car?
if the breakup in the ingition is from idle to 3500rpm, checkout this post:
<a href="http://www.aussiefrogs.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=000874" target="_blank">http://www.aussiefrogs.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=000874</a>
Check the Bosch ignitor has a heat transfer compound between itself and the aluminium heat sink. It dries up over time, resulting in the problem you described.
