205 Valve Shims
neilc
VIP Paid Subscriber
Sunshine Coast
Currently adjusting valve clearances as a result of camshaft change and finding shims that will provide correct gaps is proving a challenge. Precision shims only have flat shims of 13mm diameter or 13.8mm the Peugeot shims are 13.4 mm. I was wondering what other members have done.
Perhaps Euroserve would be able to supply some given the time they have been playing with these cars.
I turn down Ø14 silver steel rod, then cut and face to size on the lathe. Harden & temper and you're done.
It is not that big a difference from 13.8 to 13.4. You can sand the difference down using a stub arbor with a magnet in a hand drill. Tedious, but if you don't have another option...
I always use the Precision Shims, no problem.
