Hi all,
In a 720 deg cycle, with 0 being TDC on cyl 1 immediately before the induction stroke begins:
- at what point does the injector on a SPI Peugeot 205 Si fire for cyl 1 (maybe BTDC?)?
- does it fire 4 times per cycle (ie once for each cylinder) or maybe 2 times (ie once for each half of a 720 deg cycle) or maybe just once per cycle or something else?
- does the timing of the injector opening change (eg relative to rpm or throttle position or manifold pressure)
Nik
Nik
