Does anyone know how to rest the fault codes on a 205 si without a proper scan tool?
I have read the codes by grounding out one pin from the green connector, but I think the list I have may include older faults.
For example I have tested the output of the throttle potentiometer, and found it gave good readings. However, I unplugged it the previous day, and it has also shown as one of the faults.
I have a miss firing engine and I’m trying to find out the current faults on the system….
For anyone’s interest, the codes so far are listed below-
12 start test
13 inlet air thermistor
33 inlet manifold pressure sensor
21 throttle potentiometer
52 mixture regulation
41 engine speed sensor
11 end test
12 start test
11 end test
