Yes, brakes on S1 or 2 are terrible. Fit 306 or 206 brakes. Even the original 247 mm size from a 306 will be a big improvement over the originals. Trouble is that you also need to fit Si hubs to use these later model brakes. Don't touch the shockers if original but very often they aren't, usually LIP brand which are leaking. DON"T fit Bilstein B4s. If you have after market shocks and can't source the Peugeot ones (I've never seen them available) fit Record brand.One area where modification might prove unavoidable is the front discs/calipers. Peugeot likes to use some idiotic five point bolts to attach them on. By now I would hazard a guess someone has already been in there and changed them to human bolts, but when I did mine, I also replaced the discs and calipers (and the M/C too) with new OEM 306 items.
Others go with bigger brakes from I think 206? whatever. I think there is too much tax to pay if you go that way with unsprung mass and for a street car, it is totally pointless.
Oher than that, if you're not racing the car you don't need modifications (and in fact you're very likely to ruin the handling rather than improve it).
hey I noticed this but was too busy at the time to askUse 405 S2 strut tops, the Baker ones will cause knocking, seems that with them the top hat section on the shaft ends up being very close to the metal top of the strut so even though it doesn't move much it will knock. This has happened more than once for me. Height is spot on don't lower.
