205 bits and pieces
GRAHAM WALLIS
Pulled out all of the stuff I had stored in a spare 205 today. Using some of it on that car but plenty of other things are available. I have a some photos let me know if you are after anything.
I’ll take the grill please.
I those are rear side window seals I'll have those please?
Sorry no, easy to pull out and fix though. Usually just need some oil on the shaft.
Hi Graham
Any chance you have decent seat belts (front / rear) from the car?
I'll take a door rubber as well if still available.
Cheers Mate
Yes. Don't need the loom as the car was running when parked.
Do the ECU give trouble?
Got spark but no activity at injection.
New pump fitted fuel to injection .
Relays click.
I don't think it will be in the throttle body. Try putting volts onto the injector. Pressure has to be right or the car won't go, maybe you used a GTi pump? Also, has to go through the TB in the right direction.
Probably not, may have a new Italian one which requires a bit of fiddling seems to be missing the bulb holder.
I've got the bulb holder so that's fine but the little stud on the side of my headlight plastic casing has broken.
When you say "fiddling" how bad are you talking?!
