Congratulations from the Renault camp..........your car looks great.
Applies to the owner too.
Just an aside -I have never met Dino but is anyone sure that he looks like that?????
Bugger. I spoke to them and they say if it's still like that in a week they'll see whay they can do. Sounds like a refund may be the answer and I'll get the right stuff from Germany. Funny how they forgot to tell me everything was generic till after I'd paid them about $700.everyone I know who has used those door rubbers has same problem
the rubbers take a long time to squash
Doors were closing fine with just that section in place.check that the vertical rubber on the B pillar is not cause of hard door closing
I used a softer section there it seemed to help
Yeah I thought so. The originals are all fairly well sealed with some hard grey stuff. I thought I'd just lift the flap and run round afterwards with the mastic. By the way, I'm getting screen rubbers from germany as Spectrum has been saying they'll get them in about a week since about last November. Lucky, I wouldn't want to be dealing with dodgy screen rubbers. Dodgy door ones are bad enough. Nearly a day's work fitting them so far and the same stuff on the boot is just not too good either. It looks like it probably seals but it pushes the lid out so the alignment is worse than I was hoping for. Bugger.if you want your screens not to leak advise using a mastic.
it is possible to add it later either way is messy
cheers
Well I've given up on Spectrum and will instead be ordering from here:I got the correct section door rubber from Neoretro (France) for my 203 wagon. At 48.50 euros for 14 metres it was nearly half the price Spectrum wanted.
Still waiting for a windscreen rubber from Spectrum - they said six weeks four weeks ago.
www.veteranen-fischer.de
They seem to have a lot of good stuff to suit our cars and they have an English section of their website.
I'm now regretting not getting it all from there.
Wildebeest,
Does the silicone spray soften the rubber up to allow it to compress more? I have some and will try that if so, thanks.
Make sure uuse the silicon very, VERY !!!!!!, sparingly. It was used to fit the lower screen to the 1923 Peugeot Type 175 I owned and every hot day the silicon dripped out of the frame and onto the scuttle below it. Annoyed the **** out of me all the time. I told the bloke in Marseille who bought the car from me about the problem and hope he was able to fix it (maybe they don't get days over 25 so the problem might not arise).
FLASH
it allows it to slip and mould in better so it doesn't really let it compress anymore just allows the rubber to move into a place where it wouldn't otherwise move to due to the lack of friction between metal/paint and rubber if that makes any sense
John,
The problem was that he used the spray stuff and used it copiously. Being a split screen he used it to slide/ease the glass into the rubber from the top (it had no bar across the top so the glass was "open" to fresh air at the top) and as he had replaced the old plate glass with laminated glass it was thicker and so needed a bit of help. The silicone leaked from each corner every time the weather got a bit hot and this thin greasy green line, which was so hard to remove, ran down the scuttle. Looked b****y awful. I owned the car for over 15 years and it did it the whole time I owned it.
FLASH
