Hey guys,
Recently replaced the barrel that holds the 'clutch operating rod'. The thing was worn beyond belief and was not getting a direct pull on the thrust bearing fork. I filed out the holes on the Jackshaft lever and used a bolt of slightly bigger diameter to form a new barrel (see attached).
Checked clutch bearing and has 5mm worth of carbon on it.
Clutch feel much better and actually springs back now.
Also tightened the adjuster nut on the steering column for linkages, not much difference
Got a slight issue though. The old girl will not go into and gear whilst engine is running, although, when I put it into 1st gear with the engine off, then start it with the clutch down, it starts and doesn't creep or jump forward. I then slowly release the clutch and the the car will drive in 1st gear. I give it a slight rev, then I can change it out of gear into neutral, but once in neutral will not go into any gear again. Same as reverse.
The fact that it starts in 1st with the clutch down and doesn't move until I release the clutch tells me that the clutch is engaging and disengaging.
The fact that it doesn't go into gear when started in neutral makes me wonder ....
Is this an issue with worn linkages or clutch operating rod out of adjustment? The gears change fine when engine is off and linkages seem to do what they are supposed to but I guess when the engine is on, possibly there is more pressure to shift?
Thanks guys
Thanks guys
