Hi guys,
Having a bit of trouble with my doors. The 2 front doors need to be slammed HARD to hit the second striker. Which, after observing others 203's, know is not necessary. Also passenger front is now snagging on side skirt. There is a bit of wear/play on the bottom hinge on passenger side which may have caused it to drop slightly. Can slightly rock door up and down with wear.
Wondering if anyone knows if there are adjusters inside of door and if not, whether to make shims to correct wear points in bottom hinge?
If this is the case, does anyone know how to remove door pins? Have wacked them with a punch and hammer after soaking in wd40, to no avail. Such an awkward position to wack it from below while being seized.
Thanks in advance fellas,
James
James
