2015 508 auto: gearbox fault repair required
pugWA
perth
Hi all
2015 508 SW 2.0L diesel automatic - began 'clunking' on moving off in Drive from traffic lights, problem got progressively worse until 'gearbox fault repair required' warning light came on and transmission locked in 3rd. Was a v hot (40C) day. After cooling off problem has disappeared and nothing shows up in the fault check. Anyone had or fixed similar issue? Vehicle has done ~135K and recently had major service by Peugeot dealer
Any/all help appreciated
Can you provide the OBD fault codes? I am wondering if there is a transmission cooling problem.
Dont have a diagnostic unit to get codes. The car's 'check' process reads no faults...
The check function only covers a small number of thousands of faults and invalid sensor readings that are logged by the system. It isn't very useful most of the time.
When the short message displayed a more detailed error code (or codes) would have been simultaneously logged by the transmission ECU and stored for inspection.
