• Tapatalk and Mobile iOS/ Android APPs no longer supported on aussiefrogs.com. Please delete on your device. Use the web interface instead.
2001 PEUGEOT 306 CABRIOLET REAL LHS WINDOW WANTED
Hi All,
Looking for the mechanism as described above. My motor works, but the cable is a mess of kinks, so anything you may nave that could help get it working again would be appreciated.
Carl
0415 476 474 or 476474@gmail.com
Thanks.
Matthew
if you get onto ebay the cables etc are avail, but if you find the nylon runners are broken let me know, I 3D printed some replacements and they worked a treat in mine. Your call.
Other wise pull it all out and rebuild it and straighten the cable out? Not too difficult, removing the rear screw is the hardest as its behind the rear seat edge, pull it back. you will see it.
Hi. Thanks for the advice. I looked on Ebay, didnt see mechanisms for the rear, lots for the front though. I removed the assembly, the cable is a crushed and kinked mess. I think I have found one, a guy in Taree has a few cars he wants to get rid of.
