Looks like you found a dead mouse in there as well
Hi Geodon The fuel filler collar on mine is a General Motors part that came with the ute ,my guess is that its from a Kingswood station wagon . The 404 sedans have a different system.
I stripped my dash to paint it the wiring is a mess and missing a lot of numbers so thats the next challenge .
A lot has been done since the last post the 404 ute is registered and driving with a BA 7/5 gearbox and column shift running a 505 square port motor with a weber carb . I am still working through minor issues and fine tuning changing from 2nd gear to 3rd needs work and the fuel gauge does not work .How should the gauge work I have checked the earth on the new sender filled it with fuel ,still no difference when the ignition is turned on the needle does not move until you tap it then it jumps to the empty line .I have checked the voltage from wire [no 65] leading from the dash cluster to the sender and am getting 7.44 volts at the sender this makes no sense .
Should I pull the new sender from the tank and check it with a multi meter ? how should this be done ?
Marty
