Given the long seat to seat duration and the 240 degrees at 50 thou, the cam is like the competition cams of Renault that lift and lower to the seat relatively gently and is perhaps a guide to cam longevity. Are your tappets flat as original or have a 2thou convex? I also use around 80-85lb on the seat and 220lb on the nose, again maybe not helping cam life.Timing: Exhaust opens 81 degrees, closes 49, Inlet opens 46, closes 78, duration 240 degrees. Lift: inlet and exhaust .275 thou. There is 85 pound spring pressure on the seat.
The titanium retainers for the Manley springs are to suit 8 mm stem, .935 thou OD with 7 degree valve lock. The valve locks are SB Chev, LS/LT1.
From a flow bench test done long ago on one of my heads there is very little to be gained by lifting beyond 450thou, and at 412 your cam is more likely to stay in shape. From the flow bench figures, at 450thou lift at 7600rpm the head was capable of 180hp as a 1600.
