PRV camshafts etc.
Ad infinitum, two words from my last post.
Thanks for the refresher course on the evolution of the PRV6.
The technical description of the V6's having long been burnt into my mind after spending the years from 1973 to 1995 earning a crust as a mechanic with the main Volvo dealers in Perth, Adelaide and London.
I must take up on your reasons for the early V6 having different ign. timing for each cylinder bank with the intention of getting it to run smoothly.
The ignition was set up like this in order to match the sequence of the pistons arriving at or near top dead centre. It certainly wouldn't run smoothly if the ignition was arranged evenfire. I'm not being facetious here.
Various other ideas were implemented to even out the intake pulses. The "octopus" inlet manifold was later changed to a "log" manifold with the addition of a vacuum pump for the brake booster, so there must have been some strange goings on with this motor. There were two manifold balance screws on the log manifold, one was screwed out 5 turns the other 1.5 !
When the later "staggered crank" 280e V6 came along the ignition timing was changed, even fire, because the crank design meant the piston travel sequence was altered along with the cam timing as mentioned in my earlier post.
I am calling barleys on this subject otherwise ad infinitum will take over. :wink2:
Feel free to chat among yourselves
pugrambo said:The PRV V6 was an engine that had basically 2 series.
the original PRV6 had different ignition timing for each cylinder bank.
This was because the block was set at 90 degrees and to try and get it to run smoothly
the 2nd series came in around 1986 and we got it in the volvo here and the renaults got it but we didn't get it in the pugs here, well not in RWD format anyway. the 605 got the even fire but they aren't a common car. anyway that's getting off track
these engines had the 30 degrees offset journals making them a 6 journal crankshaft instead of the 3 journal 120 degree crank in the odd fire and this was to give the even firing intervals of a 60 degree V6.
now then seeing as the PRV is OHC the LH is different from the RH that we all know and hence why when looking at the engine it makes sense to look at them as 2, 3 cylinder engines
makes sense to me as it always has done
