- Joined
- Aug 2, 2000
- Messages
- 11,454
DoubleChevron said:Don't worry Greenblood, Luis seems to have a real infierority complex about his poogoe :roflmao: :roflmao: :roflmao: Maybe he's sick of Citroens leaving the the old Poogoe eating dust.
Erska, do you still have the XM. I'll check the workshop manual and see if it covers the 24valve V6. The easiest way to get this motor running will be to wire in the pre-existing computers and wiring harnesses. Be warned this isn't a job for the faint hearted. Given you have the ability to get this motor to fit in the 504, I have no doubt you will get the motor running using it's injection if i can find the wiring diagrams.
Can you get hold of a petrol tank from an injected 504 The XM tank even if fitted may be to much for the 504's rear suspension.... Possibly as a real challenge you could move the hydractive XM suspension across, you then wouldn't need to worry about the weight of the fuel tank and motor :roflmao: :roflmao: she'd all simply self level. You would also then have best handling and riding 504 in the world :banana: The XM fuel tank is 80litres so may flatten the old 504 rear springs out when filled.
One easy way around the fueling maybe to fit an LPG gas research system. If you tuned the car well to run on LPG it should be cheaper to run and still quite fast (you may struggle once again with the weight of the LPG tank in the boot though).
seeya
It seems to me that most of the performance of the 24v motor comes from the electronics, why the hell would you want to get rid of it?
If you want to live in the past just get a 12 valve engine and muck around with that, not a rare 24v.
I wouldn't have thought an advanced car such as an XM would have had an overweight fuel tank.
Graham
