my 205 mi16 rally car project.
jew086
umina beach
As the title say's im building a 205 gti rally car with a mi16 motor, custom rear suspension and tunnel.
The motor is stock, the gear box has a mixture of be1 and be3 ratio's, and will be getting a tran x LSD.
The aim is to make the car as light and strong as possible. It is being built in my garage
with help from my step dad (rally).
The car is being built by us including the painting once finished.
Anyway i wont bore you with talk here are some pics of the progress so far.
well yeah pics are good, but it's ok, bore us with talk :)
this seems quite hard core - nice - excuse my ignorance but i dont understand the replacing the tunnel, it didnt look like you were putting in 4wd in other shots.
Thats proper brave of you changing the rear suspension for something custom.
What have you got in mind?
Chris
The tunel was replaced sso that there is more clearence around the exhaust if i ever need to take it out in a hurry. and to try keep everything as hogh up as possible.
Looking at the positioning of the rear strut towers seems it will have a much wider track?
Graham
Chris
the rear suspension i am using is 205si front struts hubs and brakes so its going to be fully adjustable (toe, camber) and its aslo way lighter than the rear beem.
Maaaaate,
That is one mofo of a job your doing - Looks Great. Keep posting pics, we all love pics.
Moo
Since Andy is involved, I know it will be properly thought through, and legal, but I must say I'm surprised. What events will it be run in, and what as?
Tim
Tim
Will be OK for AMSAG, might have problems with CAMS road events.
Not as way out as the V6 engined early model Laser I saw recently with corflute flooring, perspex and plastic everything, no windscreen and no cage, now that is light! This was being run in an autocross. Was built by a Ford engineer so maybe he knew what he was doing.
My somewhat more conservative 205 has its rally debut soon, shake down run in a Khanacross yesterday saw some impressive speed, not that I will be repeating this in the rally I still have a lot to learn about FWD on rally roads.
Casnell's 205 also makes a return soon, good to see a few gravel 205s coming on the scene.
Graham
cool project, nice cage. Keep the pics and comment coming.
Interesting. I would have thought it would have been better to start with GTI gear rather Si gear to make adjustable. Same goes for the Si rear.
Learn something new every day.
Goodluck with it all.
Chris
I think if I was going to this much trouble with the back end, I would have fitted wishbones, for a truly adjustable set up.
The struts will still have some of the problems of the trailing arms - i.e. 1:1 camber gain with roll. However, you will be able to set some static negative camber, and adjust the toe.
I have never been involved in anything where these changes would be allowed, hence haven't done much other than conceptual work on this, but the wishbones shouldn't be too hard.
Good luck,
Tim
Chris
Front has been left as GTi, Si struts in rear only?
Graham
Yeah the front is still gti, the rear is made from si as it is lighter and easyer to make fit, due to the lower control arm has the sway bar/stabiliser built into it.
I am also putting a cabel shift and getting rid of the gear linkages.
My plan is to run it in the 2wd masters, and AMSAG.
a few more pics of bracing to the front towers. and into the engine bay from inside.
