Help advise wanted please
kysha
New member
Lakes entrance Victoria
Hi all. Iv got a 2006 megane convertible coupe.
It's coming up on dash braking fault...as a result when I put foot on brake I can't get it out of park and can't start...any ideas appreciated
Check to see if brake lights are working,if not working check fuses,because I think shift lockout runs through signal from brake light switch (if same as later clio).if fuses ok it may be faulty brake light switch.jim
  • Like
Reactions: COL
Thanks. Brake light are working. Car was sitting for 18mths. The 1st few times I started the car it was perfect...then I took it for a drive around the block & that's when the check brake light come on.
No good from there
There is a solenoid that moves a pin to let you move from park, maybe this is faulty. Also there is a manual button to release from the park position. Well there is on my Renault Laguna ii.
