If you would like a mud map (circuit) , just ask.
Yes please...
Running all the current for the headlights, especially if the globes have been up-rated, risks cooking the old original switch or even starting a fire. If there is a little corrosion or other muck in the switch the higher resistance can mean the switch gets far too hot.
Meh! That should help, there isn't any insulation yet just a steel plate, I'll see how that goes.
Hi Robmac
On the old drawing you had a fuse between the +ve terminal to the relay point 87. Is this fuse now redundant?
Why not wrap the exhaust with the material available from cheap motor factors? It may not win you any race, but it will help with heat control. Or if you're rich, ceramic coating on the exhaust.
