Now that the Caravelle is sold I have a quantity of mostly restored parts for sale.
2x 32pbic carburettors, as new, vapour blasted with new jets and gaskets .$200 each
5x calipers, vapour blasted , new pistons and seal kit.2x rear, 3x front. $75 each
1x steering wheel, immaculate $495
3x speedo clusters, 1x kph, 2x mph $85 each
1x water pump, perfect with new bearings.$95
2x Road wheels, sandblasted, painted silver $50 each
5x Inner tubes , some Michelin used. $40
1x Radiator, cleaned, pressure tested $200
4x sets R8/R10/Caravelle caliper seal kits $20 each
Numerous caliper square seals , caliper holding rubber blocks, pistons, bleaders etc.
1x Caravelle radio delete panel. $125
1x Caravelle heater assembly $125
50x Renault N.O.S. wheel nuts $3.00 each
1x Generator $50
Huge selection of just about every clip or fastener needed for R10/Caravelle, all zinc replated.
Many original i.e. unrestored French shock absorbers with the peculiar rebound rubbers . $20 each.
1x Caravelle mudguard script 'Caravelle' badge $50
1x Gear lever , chromed , with perfect gearknob $110
So many other bits and pieces including replated L/R door catches, L/R replated inner door remotes with new springs.
1x Caravelle hartop restored but not assembled, all fittings rechromed, new side glass, new rubbers, new headlining $1500
DAUPHINE N.O.S. front guard, unrestored fuel tank, rear screen, heater assembly, etc
I'm in Wahroonga, Sydney, so if you are restoring a Renault and need a part, message me or PM me as I have too much to list here.
Chris Hartwell.
1x Generator $50
Chris Hartwell.
