Hi Guys,
has anyone had a C2 strut apart before. This one has been knocking over large/sharp bumps since we got it .... Everything is tight as a drum and I can't find anything loosen/broken anywhere. I noticed last week when it was backed out of the shed, it was groaning from the front corner ..... Hmm..... Strut mounts? Do the struts "fall" through the bonnet on these like Xm's and Xantias?
I figured I might be able see the condition of the strut mount if I whipped the nut and big washer off...... You can "just" get to it with a 21mm open end spanner (luckily its not tight).
Once you have this off .... there is then an "impossible" to get to 19mm nut .... A claw foot socket might do it (I never needed one of them before). Infact I don't own any tool that could get to this.
anyone owning cheap crappy tools means you don't mind, er, "slightly" modifying them.
This isn't great .... but surely that's not the cause of the noise ? Does anyone have an exploded diagram of what is contained in these struts? This thing is tight as a drum checking it in everyway I can think of.
seeya
seeya
