This is a common BX problem in that the low temp contacts in the temperature sensor take the full current of the fans in series connection and eventually it doesn't work on slow series speed anymore. I used to put in an extra relay switched by the lower thermal contact, to carry the fan current so the replacement thermal sensor would last much longer.
Another problem with this system occurs when one fan runs out of brushes. This causes the series fan setting to fail completely and only one fan to work on full speed. This is not so much of a problem on the BX as the brushes seem to last well, but it does seem to happen to most Xantias at some stage in their life.
Cheers Ken
Cheers Ken
