John, Jaycar in Newcastle Street have a good range of transistors.
JohnW said:OK, now have better picture - first serious look at the BX electricals. About 1/10 for layout and access!!
I have 12V going in (at the double wire pin on the left hand side of the fan unit) and about 56 ohm to earth on the ground wire, regardless of the position of the fan speed rotary knob. I also have two separate wires going in to the unit on the opposite (drivers) side. Can't get either of these separate pins out, full stop. Any ideas on how to shift these things without breaking anything?
Separate question - can't find the oil pressure sender unit - this particular gauge isn't working. Manual gives no clues. I've found the oil temp. sender unit - a bit abraded so it's been grounded at some time, so may be the reason the oil temp gauge doesn't work. Other instruments do work so it isn't the instrument panel earthing or power supply I guess.
Best wishes for 2005 of course.
tomsheppard said:PNP3055 is a pretty universal beast that will do but there are other trannies that may be better and more available in Oz.
If you know a tron with a multimeter, get him to test the transistor for you first to ensure that it really is duff.
Stuey said:John, Jaycar in Newcastle Street have a good range of transistors.
smiffy1071 said:This is a 1905cc petrol right? The oil pressure sender is on the front of the block, centre left. If you look behind, and under the intake manifold, you will find it. It's a bugger to get at!!! john s
Sorry I can't remember where the oil level sender is, if you need any other info, let me know, as I have a 1905 XU engine sat in the shed at work, and my mate can answer virtually any BX question, as he's had 35 of the bloody things! (mostly to scrap, so he knows where everything is!) john sJohnW said:Thanks John!!! I've two gauges not working and am steadily sorting out a few other things - pulled off the central locking control unit and refitted it and some (not all!) of the door open warning lights now work. But not all..... Still it's an improvement.
Thanks for that address, John. Are they general electronics component suppliers? (I'm installing a relay on my Mi starter and want a diode that can handle more than 6 amps - the maximum that Jaycar can supply - to protect the contacts in the relay. Otherwise it'll be three in parallel.)JohnW said:Now the best shop by miles in Perth of those that I found was RS Components at 26 Walters Drive, Herdsman (5 minutes from home but the last visited of course!!). They tested the transistor (90 seconds), said "it's all right mate" and then observed that the replacement transistor would be a something or other (no-one else could even find an equivalent and these guys knew immediately, recognising its functionality). They agreed I should replace the rivets holding it in (which I'd concluded already but at that time I didn't know the transistor was working OK). So there we are.
Stuey said:Thanks for that address, John. Are they general electronics component suppliers? (I'm installing a relay on my Mi starter and want a diode that can handle more than 6 amps - the maximum that Jaycar can supply - to protect the contacts in the relay. Otherwise it'll be three in parallel.)
Oh, and don't you get satisfaction out of that result? I would!
Stuey
Stuey
Sorry about the sub-thread emergence here, John.DoubleChevron said:Hi Stuey,
3 diodes in parallel isn't really a good answer. You may find due to manufacturing differences one diode can carry signifigantly more power than the other two. If it burns out, you then have two diodes carrying the power so they will also rapidly burn out.
1 big diode sounds like the best option.
Bill B said:Tom,
just cut the track and no change so I then repaced the full speed relay still no change and then finaly tried it with out the relay pluged in and even stranger no fans at all.
Is there any explanation for this? It looks like I am only getting fan speed through this relay?
On another matter I also discovered that the vetilation flaps are not working. There is power to the switch and the flaps work when bypassed. Only leaves the switch ? Oh and for me to test if there is power to the flaps. Can anyone explain how the switch works?
