I think there may be some confusion about Ezyouts. I have encountered two types. The first is the left hand thread variety that must be screwed into the centred and drilled hole which I have used with much success after liberal applications of CRC or WD40. The other sort is marketed by F H Prager and has a very coarse slightly left hand inclined thread. This one is designed to be hammered in. I would not use these in a fit. (Sheer butchery).
I don't think there is any confusion.
There is however a third type I have seen (and there might be others, who knows?). This one has a square shank with sharp straight cutting edges that bite into the pilot hole you have to drill (this is similar to the torx idea only it has proper sharp edges designed for the job). There is then the left hand tapping technique as well as the left hand drill technique mentioned above. They just don't work. If you have an easy job where the only problem is that the screw has sheared off but otherwise is not stuck in, yes, they might work. Exhaust studs are not the worst I have seen. Soaking patiently over a few days with WD40 usually gets them out.
Most of us here had to deal with screws well and truly stuck beyond hope (think head bolts sheared off flush with the block). You're not going to get that out with the mother of all easy outs. The only way to do it is to drill and hope. Sometimes even that doesn't work but in time you improve your success rate with practice.
