Frans, do you plan to do anything with the rockers/shafts? These are sometimes worn and having a similar problem not sure what to do. New ones are not available. What is an acceptable clearance between rocker and shaft?
I have not yet found badly worn 16 rockershafts but seen a few Gordini shafts worn. They can be 1) welded and reground or 2) new shafts made and grinded/ground to original.
That will help a lot and the wear will be halved.
I think if you're in deep water with a really badly worn rocker it can be reamed and bushed (Like a conrod)
Frans
The mounting of the toothed wheel and the pick-up is completed as well. I have failed here because the idea was to mount it on the other side but now the alternator will go there with the result that the missing tooth is now about 180 deg out. Will have to fix that!
Frans.
They will be like stand-offs so that when the sump gets a hit from the bottom, the pick-up is not closed completely and oil can be drawn in on the sides next to the stand-offs. .
does that matter? couldnt you compensate by swapping the pairs of plug leads?
Ross managed to bend both of them in the removal process (he bent it because he had the hammer).
I like to think of it as a joint effort, I dont like taking all the praise.
The engine completion is getting closer now and the only big thing outstanding is the extractor. Ross will build it when it is in the car because he has strange ideas about the route the pipes must go.
Frans.
Regards
Frans.
alexander; question: i take it you are using the TPS for a megajolt in lieu of suitable manifold vacuum?[/QUOTE said:Correct. MAP doesn't work well on sidedraughts due to the pulsing signal from where the take-off is unless you have an accumulator tank to average it out.
Frans.
