205 GTI Pug flow meter to MAP conversion - how hard can it be?
Results 1 to 25 of 28
    9,414
    Default 205 GTI Pug flow meter to MAP conversion - how hard can it be?
    Or is it possible at all?
    Main restriction is that I want to keep OEM Jetronic ECU.
    Anyone?
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    dont think it can be done, although both load sensing devices, the MAP sensor would output a different signal to that of an air flow meter, not so much in the sense of the waveform/signal/voltage/resistance etc would be different, but what they are sensing as such (although related) are different. Unless theres an off-the-shelf solution i dont know about, only option is aftermarket ECU with a MAP sensor. cleared up alot of room on my 205 mi16, ran like a dream...briefly...
    Dec 2002
    Menzies Creek
    2,566
    When I had my first Mi16, I made an 'airflow meter eliminator'. It was an analogue device consisting basically just of amplifiers, tweaking the inverted signal from a MAP sensor and combining it with a 0-5v signal modulated from the tach pulse.
    It produced a signal between 0 and 5 volts as a function of manifold pressure and RPM. It had adjustment pots for biasing the voltage one way or the other.
    It didn't work very well. It couldn't compensate for changes in volumetric efficiency through the rev range. The only way around that would be a mapped system. And then you may as well just fit an aftermarket ECU.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Fellow Frogger! Molerpa's Avatar
    Jul 2005
    South America, Argentina, That country that looks like hanging from the map... just about to fall...
    492
    This is the first question you start making, before deciding for MegaSquirt
    Quote Originally Posted by luthier View Post
    It is simply impractical to expect a petrol motor to get through too much water. That's why God invented diesels.
    9,414
    Demannu, that's the idea. Perhaps your system needs a bit more refining.
    No, I don't want to get rid of the OEM ECU. Don't have the time to mess around with all the mods, just looking into possibilities of small improvements.
    The K-Jetronic on my 17G has a MAP. The LE-Jetronic on the pug can't be that much different. I am sure there is a way to convert the signal and bring it to what the current ECU needs, but my electronics knowledge doesn't go that far.
    9,547
    17G has D Jetronic', K is mechanical, don't know why they call it "tronic.
    Far easier just to fit MS, no mucking around. L Jetronic isn't digital, just an analogue calculator.
    Graham
    9,414
    Graham
    Actually, I think it is L-Jetronic. I'll check again at home. Bloody letters.
    7,567
    There's more to be gained than just removing the AFM. The ignition curve sucks in those dizzies. Read this thread: http://forum.205gtidrivers.com/index...owtopic=140951
    Do a full conversion and hide the new gear in an old box if you must.
    9,414
    I am trying to get rid of the AFM, not gain more power.
    I see your point, and am sure more power can be unleashed from the beast, but that is beyond my scope. Right now, if I could build a simple electronic circuit which could use a MAP sensor to replace the AFM, I would be quite happy with that.
    Blue Mountains, NSW
    450
    It'd be tricky -- they read different things. The AFM reads proportional to the mass of air passing the flap, the MAP sensor just reads the instantaneous air pressure. In mathematical terms, AFM would be related to the integral over time of MAP. So I'd guess your converter would need to average multiple MAP samples and publish this as an analog voltage for the pseudo AFM sensor. So far, so good. You also have to accumulate those samples over varying periods of time depending on engine speed, and you have to publish the "right" signal as expected by the L-Jetronic controller (log scale or whatever).
    I expect you'd end up with a microprocessor based solution rather than analog electronics. By the time you've done all the research and written the software you could have hooked up an off the shelf ECU. But then maybe what you're after is the fun of the challenge.
    Have fun,
    Rob.
    9,414
    I was thinking more along the lines of replicating the MAP signal reading part of the ECU on the 17G (with the appropiate sensor) and using that as a signal source in the Pug ECU, bypassing the AFM relevant circuitry. I know this is a step backwards somewhat, but I am not really bothered.
    Your post does make light though of what is involved, thank you. I didn't realise this subtle difference.
    Not sure I understand why you'd need to write software for this?
    Blue Mountains, NSW
    450
    You'd need software if you opted for a microprocessor solution.
    I am no electronics expert. I know that such a person would have no bother making something that averaged the MAP readings over time (I suppose this would amount to not much more than a capacitor). And the other operations could no doubt be achieved with analog electronics too. But the trend has been to go digital and use microprocessors for ever more "trivial" problems. I guess this is because tuning digital circuits is generally done in software; you have to change physicial components to tune analog and that loses in the cost/benefit balance.
    Just as an aside, the microprocessor thing is a bit OTT these days. The HCS12 processor used in the Megasquirt II, comfortably able to keep up with engine management duties (squirts and sparks), is suggested for such wondrous applications as "door lock controller" at Freescale's website. Poor thing will be bored out of its skull!
    Have fun,
    Rob.
    19,465
    It's not a matter of being of OTT as much as cost.
    I recently had a project to reproduce the pulse train of a Toyota central locking receiver. The OEM remote was in $500 range and I refused to pay that.
    I looked at a clocked shift register but the time building it on a piece of vero board and the hassle of doing so.
    The solution was an Arduino development board (Freetronics actually-but an equivalent) for less than $40 at Jaycar. This included the board processor, boot loader and usb lead. The software is a free download.
    Writing the code took 30 mins, most of which was reading the blog and support forums to gain familiarity.
    In less that a day I had a working unit installed in the car at around $75 in parts total. If I had gone the discrete processor approach and made a board the cost of the micro controller and parts would have been less $10.00.
    The processors are very powerful and have analogue and digital IO as well as a host of functions.
    For getting rid of an AFM I would suggest it's the only way to go these days.
    Although the programming language can be quickly learnt unless you have a background it take a while to become fully proficient - I'm a long way off that!
    It would looking here if you are interested: http://arduino.cc/en/Guide/HomePage
    The blog is really useful in seeing how experienced programmer tackle the programming.
    9,414
    9,547
    If it worked it would need mapping somehow.
    You could have ordered an MS1 ($140) by now.
    Why exactly do you want to get rid of the AFM?
    Graham
    9,414
    Clunky and takes up too much space in a crammed engine bay.
    1000+ Posts gezza's Avatar
    Bunbury
    2,195
    Take the windscreen water reservior out that takes just as much space.....
    9,414
    The moment I can replace water with electronics consider it done.
    Bunbury
    2,195
    And the moment you can replicate a fully working afm that is smaller, that will be done too
    7,567
    You've folded. Now you've conceded in moving away from originality, this is what I'd do:
    1. gut another AFM, retaining the air temp sensor.
    2. lock up distributor
    3. fit aftermarket ECU in original case and position
    The half decent ECU will have a programmable input for the air temp sensor, so all original wiring can be retained, maintaining the OEM look of the engine bay. The dizzy needs to be locked as it will not be determining advance, but will be used to trigger the new ECU and distribute high tension.
    If you're happy with less cluttered engine bay, replace the AFM with a length of Ø65 PVC pipe painted black and screw an air temp in the side.
    9,414
    Tell you the truth, I was looking at replacing the AFM with a newer filament type model to eliminate the rough idle the flap has, but all this is just me thinking about stuff, not necessarily something that might materialise or not in the near future anyway.
    Performance wise, the dizzy is right now the bit really letting the side down, but it's not an easy modification to do as I found out. Changing the dizzy to something decent say using a megajolt seems to be the easiest way to go, but even then I need mapping, etc. Which in turn means the engine should be top notch otherwise it's not really worth it. By the time that is done, I might as well go full blown megasquirt and that brings another load of work.
    To what end? My engine is just an old DFZ with unknown history. Goes really well as it is, and to tell you the truth, the oil leak past the dizzy internal seal (spiral) is more annoying to me than it's performance shortfalls. Other small niggles include the difficult to access everything and the crammed engine bay that makes it difficult to see anything deeper than the rocker cover. For instance the timing marks on the flywheel. Maybe I'll look at cleaning up the engine bay as much as I can with a redesign and reroute of all that crap (hoses/wires etc) and see how that goes.
    But it's interesting to think about all these things and who knows? Maybe I'll find something that satisfies me.
    7,567
    The "easiest" way, not necessarily the best way, to fix the dizzy seal issue, is fit a thermostat housing and coil pack from an Si. ie wasted spark.
    9,414
    Please tell more.
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    507
    Gawd, stop trying to change electronics made during the Pyramids. Go and drive an N5 306 Rallye and then you'll give the 205 away.
    Blue Mountains, NSW
    450
    The linked page doesn't make much of a case. Two graphs with different X axes, one curving downwards, the other a straight ramp upwards. Doesn't prove much does it? Just go through a four point, rough thought experiment:
    Closed throttle, idle RPM -- flap closed; MAP 40kPa
    Closed throttle, high RPM -- flap closed; MAP 15kPa
    WOT, idle RPM -- flap slightly open; MAP 100kPa
    WOT, high RPM -- flap wide open; MAP 90-100kPa
    The relationship just isn't as simple as that link suggests (it isn't as simple as the above suggests either).
    And I agree robmac, it makes cost/benefit sense to use microprocessors, but it's still OTT. I guess I'm a bit like the early electronics researchers who thought ICs were an interesting but impractical idea "'cause you'd never be able to repair them". They didn't think they'd just become a throw away item. I have much the same reaction to something about 50x more powerful than my first computer being used to check whether it's time to unlock the door. I know I'm not right about it, but it still hits me as wasteful.
    Have fun,
    Rob.
