BA7/5 gearbox spindle
Results 1 to 14 of 14
    Jul 2004
    CLARE SA
    2,324
    Default BA7/5 gearbox spindle
    hey froggers,
    I am having trouble fitting the speedo drive into the the BA7/5 gearbox in the 504ti. Seems not to be able to go in far enough. Anyone know the correct number of teeth on the spindle drive? Wether that is the defining aspect to fitment or what other wrinkle may be denying my best efforts to get a reading on the speedo?
    gggrrrr, bugger etc etc ....
    hope you are all collectively well and happy, on average ((except dino)of course)
    ed
    Dec 2002
    Menzies Creek
    2,571
    Do you know exactly what car the gearbox was out of, ie, what diff ratio it had behind it? That will effect the number of teeth on the driving gear in the back of the gearbox, which will affect which speedo driven gears will mesh with it.
    If you know, then I can tell you the rest...
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    1000+ Posts Beano's Avatar
    3,251
    It's good to see you're well enough to muck about under cars, Ed.
    Did you just put in a different gearbox ? Or are you just replacing the O-ring ?
    Does it definitely look like it doesn't go in far enough ? Because what I usually look for is some other part in the whole equation that I have messed with....like the speedo cable, or the speedo gauge itself.
    When you drive the car without the speedo in it, can you see the upper end of the cable turning ? Can't hurt to double check.....
    Jul 2004
    CLARE SA
    2,324
    hey scott and beano,
    all is as good as can be, check speedo, check cable and drive, check have 3 differing spindle drives; 21, 20, 19 teeth, check have tried 3/4 times to fix, check frustrated
    bought gearbox from our old friend gary when at southern adelaide premises, fitted three years ago into Ti body running standard diff, 4.11 - 1, I think, behind 1800 motor
    should I try all three, one after the other and is it the trick to use a slight anti clockwise motion to the spindle while marrying the two together?
    also having trouble with kawasaki brush cutter, mtd rideon(tecumseh), ex army gen set(wisconsin) and singer sewing machine, all help appreciated
    cheers
    ed
    Banned
    sydney, australia
    11,301
    my experience with sewing machines is that it is almost always a problem with the top thread tension.
    Dec 2002
    Menzies Creek
    2,571
    Hi Ed,
    If the gearbox is from an SR/GR (I have a feeling that I know (read: used to own) the car that it might have come from), it will have been for a 3.89:1 diff with 185/70R14 tyres. The original speedo drive for that car would have been a Green 26 tooth unit. The colour designates the pitch of the teeth. That is the only speedo driven gear (from the 504/505/604 range) that will fit your gearbox.
    Scotty
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    What Wisconsin????? (army type number???).
    24V, 110V, 240V.
    Year model?
    Australian or US?????
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    19,488
    Or the bobbin race is out of time with the needle. This causes a grating noise and poor stitch looping.
    Old style sewing machines are very similar to old time 35mm projectors in the way they are made.
    Jul 2004
    CLARE SA
    2,324
    hmmm, thanks alexander and rob, both areas of keen observation for me; have fiddled with both and feel the problem relates to both, lots of poor stitch looping that's for sure
    green 26 scottie, thanks best start looking for one, basil? now to see if i can concentrate long enough to work out the speedo error through Ti diff and 205/65 15 tyres hohum
    cheers guys
    ed
    Jul 2004
    CLARE SA
    2,324
    Quote Originally Posted by Gamma View Post
    24V, 110V, 240V.
    Year model?
    a BKNDA Wisconsin 1987 model maybe, 110 & 240 volt 2.5 kva aussie army, dunno army number, will look
    Jul 2004
    CLARE SA
    2,324
    err guys, anyone know where I might be able to source one of these green 26 spindle drives?, have lost lewin's phone number and feel very isolated from civilisation all the way over here in georgetown SA ...
    cheers
    ed
    1000+ Posts okalford's Avatar
    Sep 2004
    11,127
    Icon3 Sewing machine help
    Hi Edge, there’s a fair bit of info on YouTube for different sewing machine problems and different models. The looping does sound like the tension. I find I have to fiddle with it ‘til I get lucky!
    Here are a couple of links but there are lots more if your internet can cope with YouTubes.
    Common tension mistakes on a sewing machine:
    http://www.youtube.com/watch?v=w2TcJk6PUxg
    Troubleshooting a sewing machine:
    http://www.youtube.com/watch?v=A2Qqm...eature=related
    Kaye
    22
    Ed if your talking about Lewin In Brisbane ph no is 07 3353 4448
    Jul 2004
    CLARE SA
    2,324
    many thanks pug2010, exactly of whom I was seeking, confused even myself with talk of Basil, who I am sure has some relevance but cannot remember what, alas ho-hum
    thanks for the tip kaye, have to fix generator before can use sewing machine again, haha, have had various more fiddles since last mentioned and ever hopeful an angel will descend to my shoulder and the world will again become my oyster, trust you are well and thriving
    cheers
    ed
