Peugeot Coil Pack !!
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,805
    Default Peugeot Coil Pack !!
    The Electronic guys on "The Frog Panel",
    I would like to run the 4 in 1 coil pack as I have seen on some Peugeot and Citroen. I presume they are run off of a crank or flywheel trigger?? Do they run through a module or only through the ECU? and I presume it is a "lost/wasted spark" system ?? Picture attached.
    Attached Thumbnails Attached Thumbnails Peugeot Coil Pack !!-peugeot-coil-pack.jpg
    Ray geckoeng
    Think Old, But Run Modern !!
    7,572
    What car are thinking of running it on?
    You need the thermostat/dizzy housing from a 205 Si etc. Yes, it's a wasted spark system. The ECU is fed from the normal 60-2 Motronic crank trigger. The ECU has two ignition outputs, one for cylinders 1-3 and the other for 2-4.
    Perth, WA
    1,805
    Default The Motor !!
    Hi Peter T,
    I want to run it on a Renault 5 Alpine with Webers .
    Ray geckoeng
    7,572
    You'll need aftermarket management then. You obviously won't need the housing to mount it on. If it were me, I'd keep a look out for an old Haltech (E6S, E6K, E6X etc) on ebay and run ignition only.
