205 Mi16 Drive Shaft
Results 1 to 9 of 9
    Member 01YLE's Avatar
    Jun 2012
    Bris QLD
    89
    Default 205 Mi16 Drive Shaft
    I recently acquired a 205 Gti with Mi16 motor fitted to it. one of the items to be replaced is the LH drive shaft.
    I went for my first drive in it last night. Was exciting, no power steering just a big go kart.
    I was wondering since I am going to have to replace drive shaft, is there a heavier duty shaft, maybe 306 that I can use?
    Lyle
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,470
    Not really. Just replace what you have. What series 205 is it?
    Cam
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Jun 2012
    Bris QLD
    89
    Cam
    1987 S1 - still has drum rears.... bit scarey with all that torque. never know if you are going to stop.
    Lyle
    1000+ Posts parry's Avatar
    Sydney Australia
    1,336
    Series 3 drive shafts will be stronger but you will need to replace the hubs to suit. Just have your existing driveshaft rebuilt and see how it goes before you go to the trouble of a later model setup.
    I have my driveshafts rebuilt for $120 in Syndey.
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:47 (16V) 2019
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    Far North Queensland
    1,494
    Parry could you please post the name and address of the company you use to recon the driveshafts?
    My Silver Si is clunking away on LHS driveshaft.
    Seems to be the LHS that gives up first.
    Paul
    “A straight is merely the distance between two corners.”
    “Corners: radar free zones.”
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Subaru 4WD wagon, Toyota Hilux Dual Cab Diesel 4WD.
    Makotrac 205 GTi 06-05-2012 best lap 1 min 20 sec.
    Sydney Australia
    1,336
    central driveshaft services Queens rd Fivedock
    It was 120 per side, the cost does vary depending on what needs to be changed. My long 2 piece drive shaft fell apart in a million pieces and it cost me $200 to rebuild.
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    1,494
    Thanks Parry
    Paul
    Jun 2012
    Bris QLD
    89
    Quote Originally Posted by parry View Post
    I intended to upgrade brake system and found I could fit 306 or 405 discs and calipers on the smaller s1 205 hub. May have to go for hybrid. Made of 405 joints on 205 shafts. . I will have to sus out first.
    Lyle
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    id never use a reco'd driveshaft they cause nothing but trouble. only the needle rollers and grease are replaced (essentially) the cage is still worn, and that will cause problems to arise sooner. dont see it alot on pugs though..other brand i fix not naming names are horrendous!
