Stretch belt tool for 307/C4
Results 1 to 11 of 11
    May 2004
    Melbourne, Australia
    228
    Default Stretch belt tool for 307/C4
    Hi all
    I'm looking to purchase a tool for removing & refitting the elastic type accessory drive belt on our 307.
    Has anyone purchased one off the web and did it fit on the 307/C4 crank pulley properly?
    spiz
    16,860
    What on earth is a stretch belt Do you have a picture?
    8,496
    I was wondering the same. Sounds like a recipe for disaster when the stretch has gone out of it.
    Jo
    May 2004
    228
    will a video do?
    http://www.dayco.com.au/products.aspx?G=910&P=18040078
    I need to replace the crank pulley, and getting the stretch belt on and off without a tool is difficult.
    Just need the right one for the PSA pulley.
    Tools look like this:
    http://toolmonger.com/2009/12/08/stretch-belt-tool/
    spiz
    8,496
    Quote Originally Posted by Spiz View Post
    will a video do?
    Well I learn something new every day here on AF.
    Thanks for the link.
    Jo
    16,860
    I'll be buggered. Please tell me the 407 doesn't have that crap on it. Imagine the pain of trying to change that without a tensioner to back off That's the stupidest idea I've heard of in ages Is it really that expensive to add a simple tensioner
    May 2004
    228
    I don't think the 407 does. Is there a tensioner?
    Seems to work ok as the original belt has 150k on it.
    spiz
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,548
    Its becoming quite common apparently, I only heard about them the other day in a group of auto industry blokes, and they were quoting various makes & models which have the stretch belt - i guess they dont need an adjuster, the stretch covers it.
    They were talking about the tool to fit the belt. I can't give much detail but I remember this - some new belts come with a "throw-away" fitting tool which is handy. You can also buy a tool for about $30 to fit the belts. One bloke said he recommended getting the make of tool which removed and refitted, but I cant remember what the make was. Otherwise the technique is to chop off the old one, which is OK for high Km belt replacement, but a bit of a waste if you want to work on the p/s pump or alternator, etc, and the belt is fairly new. Some had Snap-On brand, but I think that was install only.
    Another new thing that needs a special tool for normal servicing.
    Edit: Gates brochure: http://www.gates.com/stretchfit/asse...v_brochure.pdf
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    May 2004
    228
    You're right .. another tool required for normal servicing.
    Gates has a tool "SFT001" that suits lots, including local cars (Mazda, Ford, Peugeot etc)
    Dayco Aus has available "TOOL6"
    Some belt install tools can also be used to remove.
    spiz
    May 2004
    228
    Pic of fitting the belt on our 307 HDi.
    Belt was around $35 from Repco. (Gates)
    Attached Thumbnails Attached Thumbnails Stretch belt tool for 307/C4-1-photo.jpg
    spiz
    12,283
    easy enough by the looks to make that one
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
