405 DKZ Head on 205 DFZ Block
Results 1 to 10 of 10
    Fellow Frogger! Aprilia's Avatar
    Apr 2012
    Rosebud Vic.
    175
    Default 405 DKZ Head on 205 DFZ Block
    I have a series 1 205 GTI XU9J1 engine and I'm looking to put a DKZ stock head from a 90 405 XU9JAZ engine.
    I found a post by Peter T., saying this was a good combination and would have around 10.5:1 .
    I dropped the head into a local machine shop ( not a pug guy ) to skim and 3 angle cut. He seemed to think that sort of compression ratio was not good for head gasket life and recomended a decompression plate to drop it closer to 9.2:1.
    The car will be a daily driver and I'm looking for low to mid range torque, any info much appreciated.
    9,548
    Quote Originally Posted by Aprilia View Post
    Just fit the DKZ complete.
    10.5 to 1 is too high in my experience, especially with standard management and camshaft.
    Graham
    7,567
    Graham is right. You need more cam timing and better management to run 10.5:1. Keep it at 9.5:1 max with std components.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,468
    Live on the edge!!!
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    Apr 2012
    Rosebud Vic.
    175
    If I install the complete DKZ engine, can I still use my inlet manifold and injectors, ecu , also is there any loom or wiring modifications I that I need to do ?
    7,567
    Yes, you can install the complete engine with 205 parts. However, as the head is being reco'd, I'd get the guy to enlarge the chambers slightly so that you can use a standard head gasket. It will be a much better result.
    Feb 2011
    182
    I'm running 10.5:1 (my machinist said it was 10:1 but the math says 10.5) with the SI head on the DFZ block with the standard Jetronic and Peters cam/timing with approx 11 degrees ignition advance.
    I'm loving it, seat of the pants it feels like it would give my Clio 172 a run for its money...but then maybe there's just an enhanced impression of speed in the gti. So far, 600k in, apart from some issues with the idle (which I think I've sorted now), I can't see a downside.
    Am I right in thinking you'd find out pretty quickly if your head gasket wasn't up to the task with the higher compression?
    Dave
    9,548
    Quote Originally Posted by DaveT View Post
    Dave
    Head gasket won't be a problem, more about pinging.
    The modified cam will reduce this as it drops the effective compression a little.
    Graham
    Feb 2011
    182
    Graham
    I was expecting a lot of pinging, but with 11 degrees advance I can't detect any, if I push it beyond that I can just detect it under load when hot. Maybe when the weather heats up and I have the air con on it'll make itself known, wait and see.
    Apr 2012
    Rosebud Vic.
    175
    Thanks for the info guys.
    I have a complete DKZ engine from a 91 Series 3 GTI 165,000 km, that I will install. It only needs a timing belt, tensioner, water pump and I'll check the shims. So avoiding engine surgery.
    The 405 DKZ head was one I pulled from a wrecker.
    Hopefully another month and she will be up and running.
    Attached Thumbnails Attached Thumbnails 405 DKZ Head on 205 DFZ Block-img_0062.jpg   405 DKZ Head on 205 DFZ Block-img_0064.jpg
