Douvrin Con Rods
Results 1 to 25 of 42
    9,548
    Default Douvrin Con Rods
    The rally car is going again, decided to go with the XN1 then do a Douvrin properly, incidentally I really noticed a difference going back to the push rod engine, very dull by comparison.
    With the Douvrin I'm thinking of fitting light weight con rods from something else. The bearing size will no doubt be smaller which should improve lubrication, one of the failings I identified with my run of distasters, also there is the chance of increasing the stroke for more ccs. This engine is only just undersquare so it should handle this OK.
    Thoughts anyone?
    Graham
    7,567
    Just get some made locally at PPM Racing. Cheap as chips these days.
    9,548
    Any idea of cost Peter?
    I dropped in at Crankshaft Rebuilders just then and will take the rod and crank back when Ian returns from holidays.
    Crank needs to be measured to check how much stroke can be added.
    They were in agreement that the rods were way too heavy.
    Graham
    9,548
    Graham
    Looks like $800 for a set of stock rods, surprising how much Peugeot stuff they have listed.
    Hopefully something else stock may be adaptable, design would have to add a lot I would have thought.
    Graham
    Dec 2011
    Athens, Greece
    314
    See if these guys have something that can be used or modified, probably best bang for the buck:
    http://www.ebay.com/itm/Peugeot-306-...294805&vxp=mtr
    7,567
    Certainly very cheap and will even print your name on the side of the conrod if desired! I have no idea how these compare in quality to locally made rods from PPM or Ridgecrest.
    Dec 2011
    Athens, Greece
    314
    Check with Adrian. Both Owen and I got sets from these guys some years back, they were mistakenly listed as suitable for the 504. I don't know what Owen did with his set, mine were used for a 106 kit car that is still running strong on the national hillclimb circuit.
    7,567
    Also, when you consider you're getting a set new set of ARP rod bolts, they are even better value.
    9,548
    None of this is important at the moment I need to see what is needed sizewise then have a go at finding something close. Hugely expensive to design a one off from scratch I would have thought.
    Graham
    Sep 2011
    Stockholm Sweden
    126
    Lighter conrods will be a great advantage, they they're heavy original, which you write Graham I found these in catcams but these are just the 2 liter model,( Renault 21 Turbo) unfortunately.
    http://www.catcams.co.uk/acatalog/Renault_Conrods.html
    Why should the bearing size be smaller? I am also interested in buying light conrods to Douvrin engine.
    I know a guy that has increased the stroke to 92mm in Douvrin engine, larger bore would also be a very interesting way to go ....
    Bobby
    9,548
    Quote Originally Posted by Douvrin504 View Post
    Bobby
    They are a bit big for proper lubrication, also by offset grinding the crank you can get a capacity increase.
    I would consider going 2 litre, if these rods are readily available and the other approach was too difficult. Edit: Just checked, these are for the F series engine.
    Graham
    Dec 2002
    Menzies Creek
    2,566
    Graham
    Scroll to the end, there's a set there for the R21 Turbo. Pricey though.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    9,548
    Quote Originally Posted by Demannu View Post
    OK, saw the word Twingo (typo obviously) and didn't look further.
    Yes, a bit pricy especially given you will lose 200cc.
    Graham
    7,567
    Just dig deep and get some new rods made locally. $800 is normal.
    9,548
    For a one off?
    7,567
    I'm afraid so, if you want a light weight, strong con-rod.
    9,548
    I meant cost of $800 for a special one off order?
    Surely it would cost more than their off the shelf items.
    Graham
    Dec 2011
    Athens, Greece
    314
    Why don't you just warm up the XN, with high CR pistons, QTB's and MS. Bulletproof engine, known blueprint. Is MikeL using the QTB's he bought? 170 bhp without stressing the engine too much.
    Sep 2011
    Stockholm Sweden
    126
    http://cgi.ebay.fr/Bielle-H-forgee-R...item3368fcea65
    Douvrin con rods , 2 liters?
    Bobby
    9,548
    Quote Originally Posted by ThanosK View Post
    Actually I ran it with the standard XN1 square port last sat night and didn't really think it was any slower over the ground than the Douvrin once you got it wound up a bit. Nice to get better fuel consumption too.
    Handling doesn't seem as good though, not much more weight but a bit more forward I guess.
    The suspension is really working well although I've worn out the spherical joints on the rear shocks, too much mud and grit.
    Bought some replacements with built in seals.
    Thinking a quick fix would be to fit throttle body injection onto the square port manifold, since the MS is already in place.
    The car is meant for long distance and navigational events anyway, 205 for the faster stuff.
    Graham
    9,548
    Says 2.2 as well?
    Need to contact them and ask for dimensions.
    Graham
    Dec 2011
    Athens, Greece
    314
    ...Handling doesn't seem as good though, not much more weight but a bit more forward I guess...
    I think a 15 mm spacer between the top mount and the strut tower and a thicker (27 or 28mm) front ARB will improve things a lot.
    ...I've worn out the spherical joints on the rear shocks, too much mud and grit.Bought some replacements with built in seals...
    Thanks for the heads-up on that, I will take a look at mine as well and even replace them prophylactically with the sealed units.
    ...Thinking a quick fix would be to fit throttle body injection onto the square port manifold, since the MS is already in place...
    This seems like a really good idea, better throttle response, economy and power. Not to mention your history with the Douvrin . Maybe a Wade 112 and a light head skim just to hustle things along a bit.
    9,548
    I will be shifting up the spring platforms by 15 or 20mm tommorrow, it has been working very well for clearance but not quite high enough for the conditions in the Classic Outback Trial
    I'm using the GTi front bar but still have the GR rear which worked very well with the Douvrin.
    No time to get the injection idea sorted, just over three weeks to go, and probably better to keep it simple for the Outback Trial, so stick with the Solex TMIMAfor now. Yes, the 112 works really with the square port engine.
    Graham
    Fellow Frogger! sideways_505's Avatar
    Perth W.A
    390
    Did anyone get the dimensions for these?
    1985 S2 505 GTi. Someone please sell me an S2 drivers side front 1/4 panel so I can get this on the road again.
    1985 S1 505 SRi. Parts car.
    1957 403 sedan. Aka Ruby.
    1979&81 Suzuki LJ81s.
    1980 Suzuki LJ80V.
    1981 Suzuki SJ40 Sierra.
    2000 Suzuki Jimny.
    Sep 2011
    Stockholm Sweden
    126
    Hey Graham, you have found or bought Douvrin conrods?
    Bobby
