thread
Thread: thread
    9,421
    Default thread
    Does anyone know the size and pitch of the thread of the little outlet for the booster vacuum on 205GTI inlet manifold? I have measured 8.8mm and it seems it's .7mm pitch, but these don't seem like metric sizes.
    Can it be an imperial or something else?
    ACHTUNG ALLES LOOKENPEEPERS
    Don't remind me!
    16,599
    M9x1? Sounds a bit like the thread on Fiamm air horn compressors.
    9,421
    Thank you Addo. No, it is definitely smaller than 1mm pitch. Matched against a 4x.7 screw seems to be exactly the same pitch.
    Don't remind me!
    16,599
    That was a brain fade by me. I actually meant M90,75 - that's the "other" 9mm metric fine.
    Maryland Metrics have a well-known and often-quoted thread identification chart - I'd looked it up there:
    http://mdmetric.com/tech/tict.htm
    9,421
    Thank you very much, addo. That sounds about right. Maryland metric is very good. I found Allen head 7mm bolts there some time ago. Now to find a tap.
