Workshop Manual R5A/G !!!
    1000+ Posts geckoeng's Avatar
    Perth, WA
    1,804
    Default Workshop Manual R5A/G !!!
    Hi Froggers,
    Would anybody have a genuine workshop manual for a R5 Alpine ??
    I would like a digital copy of the engine and gearbox, please !!!!
    I have for the R8G gearbox, R16 TS gearbox, R16TS motor, and the PVR V6 motor.
    Thanks, Ray
    Ray geckoeng
    Think Old, But Run Modern !!
    Feb 2005
    rosevale/tasmania
    2,924
    There is a Renault 5 enthusiasts' web site in the UK (& no, I don't know the URL); I'd be astonished if they couldn't help.
    Incidentally, I have just had twin 40 DCOEs dyno set up on my internally unmodified A5 engined 4CV (64.8 KW at the wheels); so if you are considering Webers on your engine & you'd like the numbers of the jets, tubes & so on, then pm me & they should be a close approximation of what you'd want. cheers! peter
    cheers! Peter
    4,472
    I wouldn't mind a copy of the jetting please.
    May prove useful for mine if I ever get the twin inlet manifold sorted.
    KB
    KB
    Perth, WA
    1,804
    Default R5 a/g !!!
    Hi Pete,
    Have spoken to Andrew at R5gordini already, he is looking for me.
    The Alpine I am building is a bit modified inside, cam, high comp pistons, and 77mm, with porting and magic valve angles. So thanks.
    Aussie Frog Brian has come to my initial help with a Haynes unit, so we can just wait.
    Thanks,
    Ray geckoeng
    Feb 2005
    rosevale/tasmania
    2,924
    KB
    Sorry about the delay, I had lent a crucial bit of paper & had to retrieve it. As bought, I ordered R8G 1300 bits as listed in a file on Katrina's Renault Page (not sure if that is still up). These were:
    Main Jet 120-125
    Air compensation 200-220
    Idle jet 45
    Emulsion tube 45 F8
    Choke tube 32
    Additional R8G info gave:
    Needle valve 150
    Float 23
    Float level 5/11.5 mm.
    I ended up with some changes:
    Main jet 135
    Air compensation 220
    Idle jet 50 F6
    Emulsion tube F7
    Choke tube 40
    Hope that helps shorten dyno time. Peter
    4,472
    Thanks for that.
    Are you sure it was 40 chokes in that last one - didn't you say these for for 40DCOE's; or are what I'm thinking of not the choke tubes?
    KB
