What is this plug for? Plus brake question
    May 2012
    Melbourne, Australia
    68
    Default What is this plug for? Plus brake question
    Car : S3 205 GTI
    Any idea what the plug is for? It runs along the back of the engine bay up the top from right to left (when viewing engine bay from front).
    How does the brake system work on the 205? Since i have rebuilt the engine something is just not right with the brakes, it feels like i am not getting any assistance from the servo, the brakes are absolutely terrible.
    Do the brakes rely on any power to boost the system? or is that not how the servo works? (is it purely hydraulic or rely on some kind of electric pump?)
    Not sure if the plug i am asking about is related, it happens to end just at the brake master cylinder/servo
    Maybe i just need to bleed the brakes...the pedal doesnt feel too mushy though!
    Any suggestions?
    Attached Thumbnails Attached Thumbnails What is this plug for? Plus brake question-photo-1-.jpg
    9,570
    Quote Originally Posted by jack205 View Post
    Car : S3 205 GTI
    Any suggestions?
    Vacuum booster, there should be a hose from the inlet manifold to the booster, (Master Cylinder sits on it).
    May 2012
    68
    I cant see a hose going from the booster to the inlet manifold ? where does it connect to each? As per haynes, when the pedal is applied whilst the car is being started the pedal drops a bit, so that would suggest that at least some suction is being achieved? Does the plug come into consideration in all this?
    Thanks for your help Graham!
    9,570
    Plastic plug in the front of the booster, don't know about the other end in a S3.
    1000+ Posts djvu205's Avatar
    1,415
    That looks like the diagnostic plug to me. The booster hose should be pretty obvious it goes from booster to inlet manifold just above the throttle body.
