205 gti soft-roader
Results 1 to 25 of 37
    Feb 2011
    182
    Default 205 gti soft-roader
    I finally got around to refurbishing some 15" Speedlines I bought a while back. Countless hours of finger and back straining sanding that will require years of massage and psychotherapy to put right... but hey at least I saved a couple of hundred dollars. Anyway they came up incredibly well, much better than I was expecting...so of course I put a ding in one of them with the wheel brace.
    I had this idea the speedlines would fill in the acres of empty wheel arch space the pepperpots didn't...until I realised with the lower profile tyre they're the same diameter, perhaps even a tad smaller
    So it appears I have a 205 gti soft roader...one of my friends even asked today if I'd jacked the suspension up...very depressing. After reading many posts on the subject I'd rather not lower the car, but I don't think I can live with the soft roader look.
    The car's only done 128,000k and the rear suspension as far as I can tell is all original and seems in great nick, so I'm assuming the rear height is as per original, it's currently sitting at 345mm centre to centre.
    I recently put new struts in the front, I went with Quinton Hazell Liptec gas shocks based on a few recommendations, this article http://www.eai.net.au/lipmesa.html ...but mainly because they were only $80 each. They feel good, firm but supple and not crashy, pretty much like the OE ones I had on my old GTI. But the front ride height is now 365mm c/c.
    Anyone have any experience of new gas shocks raising ride height...and if so, did they settle or lose height as they got older?
    Apparently 320mm c/c is a good height to aim for with the rear...but to bring the front down to the same level I'd need to have them reset 45mm lower, which seems a lot, should I go for something like 35mm to allow for 'settling' as they get older?
    Dave
    Far North Queensland
    1,494
    Wow you certainly did a great job on those wheels Dave.
    Would be hard pressed to get a professional job looking as good.
    What profile tyres are you running?
    My GTi is running 195/55 x 15 but it is lowered all round.
    Be interesting to see how those front struts last, sound like good value.
    Paul
    “A straight is merely the distance between two corners.”
    “Corners: radar free zones.”
    Current: Peugeot 205 GTi Mi16 1987
    Peugeot 205 Si, one red one silver, both 1991.
    Peugeot 504 Wagon, V6 and 5 speed gearbox.
    Isuzu (Holden) Rodeo, 4WD dual cab, extended chassis.
    Past: Goliath, Isuzu Bellett, Austin A30, Peugeot 203, 403, 404, 504,505.
    Subaru 4WD wagon, Toyota Hilux Dual Cab Diesel 4WD.
    Makotrac 205 GTi 06-05-2012 best lap 1 min 20 sec.
    1000+ Posts gezza's Avatar
    Bunbury
    2,195
    It maybe the angles but that looks very high off the ground..!!!
    You could lose 45mm all round easily off that...
    9,414
    Quote Originally Posted by DaveT View Post
    Dave
    What did you do with the wheels?
    Paint them?
    ACHTUNG ALLES LOOKENPEEPERS
    9,548
    Dave
    Doesn't look high at all but on GTis the guard extensions stick out too far. They are not actually needed, my Si rally car has 15 inch wheels and they clear fine.
    Graham
    Feb 2011
    182
    Thanks Paul, I'm running 195 50 r15 Kumho ku31's, had a couple of new ones put on the front...I should've cleaned the tyre grease and finger prints off before I took the pic.
    I painted them with VHT wheel paint...this is the third set of wheels I've done over the years using the VHT paint and these ones came up the best. VHT make a quality product and if you prep well, follow the instructions on the can to a T and paint on a warm, windless day the results are fantastic. Only downside is the paint isn't as hard as the original or I guess powdercoating, hence a glancing blow with the wheel brace, that probably wouldn't have left a mark on the original finish, left a little dent in the new paint.
    I have to take the front apart again to sort out some gearstick wobble and replace a new driveshaft seal that's leaking hmmm, maybe the two are related... anyway, since I'm doing that I thought it's a good time to get the ride height right, but I don't want to lower 45mm all round then have the car settle a further 10...is this likely/possible?
    Dave
    Melbourne Australia
    1,382
    The cars do sit high as standard but not quite that high. Depends how much it bugs you I suppose as to whether to drop it front and rear as there is a bit of work in resetting heights. What was wrong with your standard struts ?
    1,494
    Dave, I haven't had experience with new struts so can't give you any advice on settling.
    Not sure how much my car is lowered but attached are some pics of whees and wheelwell.
    Also running 195/50 x 15
    Paul.
    Attached Thumbnails Attached Thumbnails 205 gti soft-roader-jse_p1040974.jpg   205 gti soft-roader-jse_p1040975.jpg
    Feb 2011
    182
    I think at some stage a previous owner had snaffled the OE front struts, in there place they'd put in some mismatched aftermarket struts, one of which was very tired...which made for some interesting handling characteristics. The rest of the front end was in great nick.
    I'm almost certain the rear of the car hasn't been touched, it still has the OE rear shocks and everything looks untouched, nut/bolt heads all perfectly square, and there's no mention in the receipts of any work to the rear. If that's the case the rear ride height should be the original standard height...so I'm wondering, can the front ride height affect the back... if the new front struts have pushed the front up a bit, could they be affecting the back as well?
    I guess it comes down to personal taste...as Graham said, it doesn't look high to him...for me, although I would rather not lower it, I don't think I can live with it like this.
    Dave
    Feb 2011
    182
    Paul, your 205's ride height looks just about perfect...jealous
    1000+ Posts djvu205's Avatar
    1,415
    have a look at the front control arms a car lowered 30-35mm will have the arms sitting nearly horizontal.
    9,548
    Quote Originally Posted by Andrew Ch View Post
    After having a look at mine I have changed my mind, yes, yours does seem a bit high.
    Did you let the car settle before doing up the nuts on the lower control arms?
    It could be raise due to tension the bushes, which will fail quickly if that is the case.
    Gas shocks will add height. This was particularly bad in 504s, which have soft suspension.
    Graham
    Feb 2011
    182
    Graham, yes when I did all the work on the front end, brakes and driveshafts about 6mths ago I left the lower control arms loose, lowered the car onto it's wheels, bounced the front up and down, let it settle then did the arms up. I loosened them again yesterday, bounced up and down on the front, let it settle then tightened...no difference.
    The arms appear to currently have about a -4 degree angle.
    9,548
    You need to push the car back and forwards or drive it, the wheels move sideways slightly as they go up and down due to the McPherson Strut suspension design. which they can't do due to friction if you simply lower it.
    Graham
    Melbourne Australia
    1,382
    Just had a look at my S3 GTI and thought I would give you some measurements of my standard setup albeit with original size 185/55 tyres and a photo of the front.
    Height from ground to centre bottom edge of front arch - 625 mm
    Height from ground to centre bottom edge of rear arch - 615 mm
    1,494
    Default lowered 205 GTi
    Quote Originally Posted by djvu205 View Post
    Thanks djvu205.
    looks like thats where mine sits.
    Dave the underside of your car is a lot cleaner than mine.
    By the looks of it the outer boot might need a bit of a look at too on mine.
    Paul
    Attached Thumbnails Attached Thumbnails 205 gti soft-roader-jse_p1040987a.jpg
    Feb 2011
    182
    Thanks Andrew for the measurements...a great guide because I know your car is one of the nicest, if not the nicest, original 205's in Oz.
    You don't happen to know the outer diameter of your 185 55 tyres do you? I had a look online and a few resources say it should be 585mm, but then they say 195 50's are 577mm but when I measure mine I'm only getting 563mm....
    The same ground to middle under side of wheel arch on mine are:
    Front: 642mm
    Rear: 622mm
    Quite a way off yours.
    When I get a spare 5 mins I'll have a go at loosening the control arms again and driving it around the block, but I think it's optimistic that this will lower it 20mm.
    If it is the gas shocks causing the raising, is it wise to reset the springs compensating for this raising?
    Thanks guys really appreciate your input.
    Dave
    1,415
    google "wheel and tire bible" it has a tire calculator which is handy and heaps of other info
    1,415
    what the hell heres the link
    http://www.carbibles.com/tyre_bible_pg4.html
    check out this link also if you decided to reset springs
    http://autospeed.com.au/cms/title_Re...6/article.html
    Melbourne Australia
    1,382
    If I get a minute tomorrow morning I will lift car and measure actual diameter of my tyre so you can do your sums.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,468
    Default ???
    As Graham says: "Did you let the car settle before doing up the nuts on the lower control arms?
    It could be raise due to tension the bushes, which will fail quickly if that is the case."
    ie Slacken off the nuts on the lower control arms with all the wheels on the ground (no jacks) then bounce the car up and down on each corner a few times and then with the car still supported only on its wheels, nip the nuts up. It is worth a try!!
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,548
    Quote Originally Posted by BIGRR View Post
    Yes, but as I said you need to push the car back and forwards or better still drive round the block to get it to settle properly.
    Graham
    Feb 2006
    North Rocks, Sydney
    2,468
    Default Need Glasses
    Graham
    Graham,
    just got hearing aids, I will put in order for glasses today .
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    lost
    11,055
    Icon6
    It could be raise due to tension"
    G'day,
    sorry, wrong forum...
    regards,
    Les W.
    206 GTi 180
    the stealth Pug
    Feb 2011
    182
    Just loosened the control arm bushes, been round the block, over some bumpy bits, reversed and braked hard. Tightened back up and still getting 642mm ground to centre wheel arch on the front.
    On the back, and I'm not sure if this is just with drum rear cars (I did notice it with my other drum rear gti) but if the handbrake goes on whilst your foot's still on the brake, the back of the car squats, and with this squat I'm getting 615mm, same as yours Andrew.
    I took the previous photos and measurements with the handbrake off, the photos below are with handbrake on and at a better angle.
    Andrew is it possible you could take a measurement of the diameter of a front tyre with the wheel left on, and then one of the gap from the top edge of the tyre to the centre underside edge of the wheel arch? This gap on yours doesn't look all that different to mine, so I'm wondering how much the height difference is to do with the tyre sizes and tyre wear.
    I'm running brand new Kumho's on the front, and I would guess there could be 10mm difference in the tyre diameter between new and worn...not suggesting yours are worn just that if I'd left my worn tyres on, the car might've sat 10mm lower....optimistic?
    Dave
