Sealed for Life?
    monbulk
    660
    Default Sealed for Life?
    I am starting this thread because the sealed for life aspect of transmissions is being mentioned in both the Citroen C5 and Renault Laguna examples. I think that the issue should be examined in depth.
    I don't want to open up the discussion to the 4speed transmissions, which, I think, are well documented.
    I will use my cars as an example of my concerns. Both have sealed for life gearboxes.
    Firstly, my Peugeot 406 SV had a 5 speed manual gearbox. When I had it serviced by a different mechanic, he drained the box at 215,000km and said that the oil was disgusting and very gluggy and amongst the worst examples he had seen. The change of oil noticeably improved the shift into and out of second gear in particular.
    The Pug was replaced by a 2007 Citroen C5 2.2litre turbo diesel. It has a 6 speed auto gearbox and 110,000kms on the odo. It too is sealed for life, but I was quoted $220 per litre for the special Citroen oil. I understand that this auto-trans is used in other brands where the price of oil is significantly cheaper than Citroen fluid.
    So, should sealed for life units be serviced with new fluids. If yes, where should fluids be sourced?
    Thank-you for your thoughts. I hope that the thread becomes practical advice to me and you.
    Da vid
    Gone Fishin' Haakon's Avatar
    May 2002
    canberra...
    8,898
    Yes, and repco.
    Am becoming less and less inclined to beleive the "it must be genuine fluid" line. Yours is an aisen gearbox, buy Toyota fluid or the synthetic Penrite etc.
    Apr 2005
    867
    you might want to check the previous thread of the same title too http://www.aussiefrogs.com/forum/showthread.php?t=96938
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    monbulk
    660
    Default Oops
    Sorry, I didn't think to check because it was a current chat. My apologies.
    David
    1000+ Posts Capago's Avatar
    Hornsby, NSW
    1,016
    lol sealed for life means it probably wont leak out the diff seals! (to a mechanic anyway )
