Great article on compression ratio!
Results 1 to 12 of 12
    Fellow Frogger! Karoshi's Avatar
    Feb 2011
    270
    Default Great article on compression ratio!
    http://www.popularhotrodding.com/tec...ech/index.html
    All Chevy based theory explanation is fantastic.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,470
    Quote Originally Posted by Karoshi View Post
    Very Interesting.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    It's how I roll...Brisbane
    34,220
    And I found my unclaimed prize at the end...
    Every day when I wake up I reach up in the darkness with my eyes shut and if I cannot feel anything that resembles a wooden lid I know it will be a good day. No lid today.
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,549
    Yes, thats a great article.
    First thing that struck me was the author, David Vizard. Probably best known for his tuning books on British 1960's cars - Minis, Cortinas, etc.
    I read an article about 25 years ago I reckon, where he went to USA for a look at the racing scene. He said he was at some NASCAR gathering/party or something, and in discussion with some quiet spoken old NASCAR engine builder, the old boy made a comment like "all decent racing engines have a compression ratio of 8.5:1" which set Vizard back on his heels. Then the old boy explained what in the current article Vizard is calling "dynamic CR". Vizard said that up to that point he had never even thought about it, but realised it was a great principle.
    It looks like he stayed there and found his place among the big-iron V8's. Maybe he was actually a yank when he wrote his first books on pommy engines - I have always thought he was a pom. His old books make good reading too.
    By the way, there is another way to measure the Dynamic CR and that is by actual measurement. My brother was a Mini Cooper S guru of sorts (the 1960's ones) and raced them at length. We once thought we would check the dynamic CR while building the engine in the stand - with the head off. Simply measured the distance from top of block to piston top with a vernier caliper depth gauge, and finding the point at which the inlet valve closed with a dial gauge on the cam follower. Then calculated CR using the "effective" stroke measurement. And yes, it was something like 8.5:1, where the static CR was about 12:1. Very interesting. Depends on the cam overlap, and we learnt that the CR must be matched to the cam. A good exercise.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    507
    That ratio can then be increased by the ram tuning of the inlet manifold length and harmonics. Another 10% or more! Most serious engine builders also do calculations at 0.050" lift off the seat as well. The static CR numbers would surprise you! 13:1 static that runs on 92 octane.
    Feb 2011
    270
    One thing I've found from poking around looking for info is that there's lots about v8s....
    7,567
    Absorb this and then install the DCR calculator.
    http://cochise.uia.net/pkelley2/DynamicCR.html
    There's no point in doing a calculation 0.050" off seat, as the compression stroke hasn't started at that point. The compression stoke starts when the intake valve closes. Duration measurements at 0.050" are used for more accurately comparing camshaft profiles. Below 0.050" nothing really happens in terms of flow.
    Apr 2011
    brisbane
    507
    Fair enough Peter.
    I find it useful to get a feel for the dynamics of engine cranking and ignition curve changes, inlet and exhaust design and cold and hot crank amps with a solid cam. Overlap, idle smoothness or lack of, etc......................
    Static and dynamic figures can help to get a feel, for me any way!
    Perth Western Australia
    2,712
    So... This means my large burette and pot of piston sealing vaseline are now redundant?
    7,567
    Did you read it? You still need to know the static CR before you can calculate the dynamic CR. So yes, vaso and burette is still needed.
    2,712
    Default Compression....
    PeterT,
    Thank the lord for that. One of the few items I have in my lockup to impress my friends!
    Peter, I doubt whether the theories put forward would be understood by current motor mech apprenti or their instructors.
    Ivan Washington [PCCV] had a great way of theorising to be understood.
    Apr 2011
    brisbane
    507
    Depends. What you do with the burette is your business, and don't let any one influence you other wise!
