405 Mi16 Roll cage
Results 1 to 7 of 7
    Fellow Frogger! NZ_Mi16's Avatar
    Nov 2003
    Hobart
    165
    Default 405 Mi16 Roll cage
    Hi all
    Anyone know a rough estimate to get a roll cage put in a 405?
    I have most of the interior out, so shouldn't be too hard (I hope)
    Also, anyone know of somewhere in Tas that does them?
    Current:
    09 Volvo XC70
    89 405 Mi16
    Past Pugs
    02' 206 GTi
    90' 405 Mi16
    Jul 2003
    222
    $2500 to $20,000.
    1992 205 Si
    Current: shortened diff (4.4), short shifter, group N top mounts, rebuilt engine and box, solid engine mounts, 1.75" exhaust, strut brace, OMP wheel, GTI suspension & subframe front and rear, lowered 30mm front and rear, solid rear bush, Koni yellows, 306 XT front discs and calipers, ADR compliant braided brake lines, 14" rallye wheels, Dunlop Direzza Z1 Star Spec tyres, immobiliser
    1000+ Posts pgti6's Avatar
    May 2001
    1,670
    405 Mi16 2.2 litre race car for sale.
    http://www.aussiefrogs.com/forum/car...-car-sale.html
    https://www.my105.com/ListingDetails...d/518/id/22164
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    435
    Many ways to do it - but in the end similar costs
    Raw Steel $400
    Bends $400
    Plates and acc $200+ approx 50 hours of your work
    Or Buy a kit $1200 approx+50 hours your work
    Or buy a kit and have it fitted $1200 + $2000 or so fitting+++
    Or get the whole lot done $$3000 - 5000.00
    9,549
    Quote Originally Posted by 205 Maxi View Post
    Raw Steel $400
    Bends $400
    Brown Davis here in Melbourne will do a basic CAMS compliant cage for well under $2000, particularly if you strip out the interior yourself.
    Anything more than a basic cage is too dangerous to drive on the road without helmets and proper seats and belts.
    Graham
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,274
    Raw Steel $400
    Bends $400
    Bends? CAMS and just about any motorsport authority will not allow the use of bends in the construction of a rollcage. IIRC all legs/sections are to be formed in one piece and 'bent' to obtain the necessary curves. This involves using a pipe bender to give a smooth and even surface.
    Nov 2003
    Hobart
    165
    Graham
    Might be worth a trip over on the boat if I can't find anywhere reasonable down here...
    Current:
    09 Volvo XC70
    89 405 Mi16
    Past Pugs
    02' 206 GTi
    90' 405 Mi16
